1721 at home with roadrunner
kidem
I cant get it working here is my config, and here is my ISP settings
Ip = 24.145.231.94 255.255.255.0
gateway = 24.145.231.1
Am i missing something, i have done this sorta before, and had No problems before.
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname Router
memory-size iomem 15
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip audit notify log
ip audit po max-events 100
interface Ethernet0
ip address 24.145.231.94 255.255.255.0
full-duplex
interface FastEthernet0
ip address 192.168.2.10 255.255.255.0
speed auto
ip default-gateway 24.145.231.1
ip classless
ip route 0.0.0.0 0.0.0.0 Ethernet0
no ip http server
ip pim bidir-enable
line con 0
line aux 0
line vty 0 4
login
tbaranski
Level 4
Level 4
Point the default route to a specific gateway rather than just an interface:
ip route 0.0.0.0 0.0.0.0 24.145.231.1
The "ip default-gateway" command only has an effect when "ip routing" is disabled.
