1721 router dropping ethernet interface
takaiwana
my 1721 router is displaying the following message at regular intervals: PQUICC_ETHER-1-LOSTCARR: Unit 0, lost carrier. Transceiver problem?
loading of the ios is also very slow. any clues of of what is causing the problem?
thanks.
erikhjacobsen
Please post the output of the show proc cpu and show int fa0 commands.
Ethernet0 is up, line protocol is down
Hardware is PQUICC Ethernet, address is 0004.dd0d.0aaf (bia 0004.dd0d.0aaf)
Description: Ethernet Link to Zimbabwe ISP
Internet address is 217.15.121.106/29
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
reliability 137/255, txload 1/255, rxload 1/255
Keepalive set (10 sec)
Half-duplex, 10BaseT
Last input never, output 00:00:06, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
86 input errors, 0 CRC, 0 frame, 0 overrun, 86 ignored
86 packets output, 5456 bytes, 0 underruns
86 output errors, 0 collisions, 1 interface resets
86 lost carrier, 0 no carrier
FastEthernet0 is up, line protocol is up
Hardware is PQUICC_FEC, address is 000b.be95.ff08 (bia 000b.be95.ff08)
Description: LAN Interface - Zimbabwertr
Internet address is 10.5.0.1/24
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Auto-duplex, 10Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 4/75/0/0 (size/max/drops/flushes); Total output drops: 0
5 minute input rate 1000 bits/sec, 2 packets/sec
5 minute output rate 0 bits/sec, 1 packets/sec
1340 packets input, 118560 bytes
Received 348 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
714 packets output, 139812 bytes, 0 underruns
2 output errors, 0 collisions, 1 interface resets
2 lost carrier, 0 no carrier
Virtual-Access1 is up, line protocol is up
Hardware is Virtual Access interface
MTU 1492 bytes, BW 100000 Kbit, DLY 100000 usec,
Base PPPoE vaccess, loopback not set
DTR is pulsed for 5 seconds on reset
Last input never, output never, output hang never
Last clearing of "show interface" counters 00:13:15
Input queue: 0/4096/0/0 (size/max/drops/flushes); Total output drops: 0
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 carrier transitions
even if the router is not connected to a hub or switch the error message of lost carrier still appears.
klauset
Sounds physical.
Most often, "Lost carrier" indicates a physical problem. Check your cabling - replace the drop cable, try another switch/hub port, test with a cross-over cable directly to a NIC if you can.
Also, be sure to lock your interface speed and Full-Duplex/Half-Duplex settings. "Auto negotiation" too often is neither.
the problem is occuring even when nothing is connected on the ethernet port.
