Community Member
1721 router help!
Hi, and thanks in advance for your help!
I bought a 1721 router from pac bell "staged" and bundled with aT1. If i change the en password and do "write mem", "reload", the password goes back to the old one, why?. Does reload mean reload from a stored image? can this router store an image? If i do show config i get "no such command". In fact the show command is tottaly unreconagized. is this normal, or did pac bell load an image and disable some commands? If they loaded an image can i kill it (do i want to kill it)? They did not include a configuration guide like what came with my pix, or i would not be asking such dumb questions! I searched cisco online.. after 2 hours of searching and testing im here writing to you! thanks for the help
Re: 1721 router help!
Hi Anthony,
After changing the enable password, write mem should update the saved config in NVRAM. You could try 'copy run start' as well in case 'write mem' isn't working for some reason. Reload will reload the router and load the config stored in NVRAM usually, unless the config-register is set to not load the config from NVRAM. At the bottom of the 'show version' output there will be a line that saids what the config-register is. What does that say? If it's something other then 0x2102 change it to 0x2102 and see if it comes up fine.
On reload, does the router perform like it was 'staged' to function or not?
What is the prompt on the router? If it's router-boot or rommon then the config-register may be incorrect.
What version of IOS does the 1721 have?
Regards, Erick
Community Member
Erick, thanks for the help.
Here is a show version, the show command only works from the en, and not after config t is entered. How can i get rid of the "image" looks like script at the end of the config appears to be what i thought was the image.
PacBellRouter#show config
Using 1690 out of 29688 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname PacBellRouter
enable secret 5 XXXXXXXXXX
enable password XXXXXXXXX
ip subnet-zero
modemcap entry line
interface FastEthernet0
description TO LOCAL LAN
ip address 192.168.100.2 255.255.255.0
ip nat inside
speed auto
interface Serial0
description PB CKT 40HCGS991156_OO1PT
ip address 64.160.180.38 255.255.255.240
ip nat outside
encapsulation ppp
no fair-queue
service-module t1 timeslots 1-24
ip nat pool webaccess 209.76.153.161 209.76.153.174 netmask 255.255.255.240
ip nat inside source list 1 pool webaccess
ip classless
ip route 0.0.0.0 0.0.0.0 64.160.180.37
no ip http server
access-list 1 permit 192.168.100.0 0.0.0.255
banner motd ^CC
East Bay Restaurant Supply
This system is for authorized use only. Individuals using this
computer system without authority, or in excess of their
authority, are subject to having all of their activities on this
system monitored and recorded by system personnel. In the course
of monitoring individuals improperly using this system, or in the
course of system maintenance, the activities of authorized users
may be monitored, Anyone using this system expressly consents to
such monitoring and is advised that if such monitoring reveals
possible evidence of criminal activity, system personnel may
provide evidence of such monitoring to law enforcement officials.
^C
line con 0
password XXXXXXX
line aux 0
exec-timeout 300 0
password XXXXX
login
modem InOut
flowcontrol hardware
line vty 0 4
password XXXXXXX
login
end
PacBellRouter#
Community Member
Ok, im now thinking i cannot change the password because there is a secret one defined? i cannot find the secret command in the list.
Community Member
the basic question stands, why i cannot change the en password. it keeps resetting to the one defined by pac bell
Community Member
FIXED THE secret PASSWORD used these commands to reset the en secret password
PacBellRouter>en
Password:
PacBellRouter#config t
PacBellRouter(config)#enable secret 0 PasswordHere
PacBellRouter(config)#exit
PacBellRouter#
PacBellRouter#write mem
PacBellRouter#reload
Anthony,
Glad to hear you got it fixed. Enable secret will override the regular enable password.
85
