1721 router kilostream connection problem
hi
i have 2 routers A and B connected via a kilostream
i can ping from router A to router B
i can ping router A to switch A on same network segment
i can ping router B to switch B on same network segment
but i cant ping from network via switch A / router A to router B or switch B segment
i have set up access lists and routing but still no joy
any help appreciated
elainee
Re: 1721 router kilostream connection problem
Please provide some info on the configuration of your routers
User Access Verification
Password:
elgin_moycroft>enable
Password:
elgin_moycroft#sh config
Using 839 out of 29688 bytes
version 12.2
service config
hostname elgin_moycroft
enable secret 5 $1$yv.1$hrX2ZsPsX8Cip/c9Jt6GV0
enable password aviion
ip subnet-zero
no ip domain-lookup
interface FastEthernet0
ip address 123.123.1.253 255.0.0.0
speed auto
full-duplex
no cdp enable
interface Serial0
description leased line to moycroft
ip unnumbered FastEthernet0
encapsulation ppp
router rip
version 2
network 126.0.0.0
no auto-summary
ip classless
ip route profile
no ip http server
access-list 1 permit 0.0.0.0 255.0.0.0
access-list 2 permit 0.0.0.0 255.0.0.0
access-list 2 permit 123.0.0.0 0.255.255.255
route-map route permit 10
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password morayside
login
end
elgin_moycroft#telnet 126.126.1.253
Trying 126.126.1.253 ... Open
Password:
moycroft_elgin>enable
Password:
moycroft_elgin#sh config
Using 735 out of 29688 bytes
version 12.2
service config
hostname moycroft_elgin
enable secret 5 $1$OzCd$POPIKHElmY/rZbfTZnwgK.
ip subnet-zero
no ip domain-lookup
ip address 126.126.1.253 255.0.0.0
speed auto
half-duplex
no cdp enable
interface Serial0
description leased line to elgin
encapsulation ppp
router rip
version 2
network 123.0.0.0
no auto-summary
ip classless
no ip http server
access-list 2 permit 126.0.0.0 0.255.255.255
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password morayside
login
no scheduler allocate
end
moycroft_elgin#
the main office - elgin network is 123.0.0.0 255.0.0.0 and the moycroft office is 126.0.0.0 255.0.0.0
tracert gives
H:\>tracert 126.126.1.253
Tracing route to 126.126.1.253 over a maximum of 30 hops
1 <10 ms <10 ms <10 ms 123.123.1.253
2 * * * Request timed out.
3 * ^C
H:\>ping 126.126.1.253
Pinging 126.126.1.253 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 126.126.1.253:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
so my server knows to route through the correct router
appreciate you help
elaine
The RIP network statements on the two routers are reversed. They should be set so that the networks (i.e. interfaces) defined to be running the RIP process match the interface IP networks on the local router:
router rip
version 2
network 123.0.0.0
and
router rip
version 2
network 126.0.0.0
This should work fine now.
Hope this helps.
Remove the Access lists and get the routing right first.
Set the ethernet Interface speeds eg full duplex speed 100 auto negotiation does not allows work properly.
Are you using unnumbered to the interfaces for the WAN links?
If you are using static routes make sure that the gateway for each route is correct on each router.
thansk for your reply
howvere i cant seem to get the access-lists off now and i cant get it to set the duplex and speed settings and keep the settings when i come out of config and do a show config
137
