Community Member
1721 Router w/ADSL-WIC Config Problem w/Verizon
I am having a problem getting my ADSL-WIC card to work with my Verizon connection. I plug it into my phone line and it pulls an IP address and proper DNS information for Verizon (one dhcp ip pulled was 71.105.142.101 and Verizon's DNS's are Primary DNS 1: 68.238.64.12 Secondary DNS 2: 68.238.128.12)
I can ping the IP address from the con 0 connection on the router and from a workstation but I'm not able to ping any other addresses or access the web.(DSLR#ping 71.105.125.104
Sending 5, 100-byte ICMP Echos to 71.105.125.104, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
DSLR#ping 192.xxx.xxx.xxx
Sending 5, 100-byte ICMP Echos to 192.xxx.xxx.xxx, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms)
When I try to ping any other addresses I get (DSLR#ping www.nightowltechs.com
Translating "www.nightowltechs.com"...domain server (68.238.64.12) (68.238.128.1 ***********(Trying to resolve with Verizons DNS's but cant find address)
2)
% Unrecognized host or address, or protocol not running.)
I had a friend take it home and it works fine on their Verizon connection but not mine. Perhaps there is something I am not seeing in my config that would help it work with mine. I have posted my running config as it worked for my friend at his house. Any help would be appreciated.
Building configuration...
Current configuration : 1214 bytes
version 12.4
hostname Yourname
boot-start-marker
boot-end-marker
logging buffered 4096 debugging
no aaa new-model
memory-size iomem 10
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.xxx.xxx.xxx 192.xxx.xxx.xxx
ip dhcp pool Mypoolname
import all
network 192.xxx.xxx.xxx 255.255.255.0
default-router 192.xxx.xxx.xxx
bridge irb
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
bridge-group 1
pvc 0/35
encapsulation aal5snap
interface FastEthernet0
ip address 192.xxx.xxx.xxx 255.255.255.0
ip nat inside
ip virtual-reassembly
speed auto
interface BVI1
mac-address xxxx.xxxx.xxxx **************************(MAC Taken from my linksys that works fine when hooked up)
ip address dhcp client-id FastEthernet0
ip nat outside
ip route 0.0.0.0 0.0.0.0 BVI1
no ip http server
no ip http secure-server
ip nat inside source list 1 interface BVI1 overload
access-list 1 permit 192.xxx.xxx.xxx 0.0.0.255
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
logging synchronous
speed 115200
line aux 0
line vty 0 4
login
end
Community Member
Re: 1721 Router w/ADSL-WIC Config Problem w/Verizon
I hope I was clear enough in my explanation of my problem. Any help would be appreciated, even an "I don't know." would let me know that someone is reading this. =(
Community Member
I have read and read about problems related to this and can not seem to find any solutions to my problem. Can someone please help.
262
