1721 router will not clear
I am trying to reconfigure a 1721 router, but we are unable to clear the old configuration data and it will not let us reconfigure...any suggestions?
Bronze
Re: 1721 router will not clear
Did you already try the command "write erase" or the newer "erase nvram:" command?
Also note, you have to reboot the router after performing one of the above commands.
-HTH
What kind of error message or symptom do you get? In any case, make sure your config register is set to 0x2102.
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
114
