1721 with WIC-4ESW Help
Hello, I have setup some pretty simple WAN links on 2600's before, but what I need to do with a 1721 is much different and I need some help. Here is what I want to do..
Setup a 1721 with 2 WIC-4ESW's so up to 8 nodes can have access to ethernet provided via the built-in FastEthernet port. Then be able to firewall each port separately (some will be web and some will be mail servers).
From what I know, I assume the way to phrase this properly is that I want to use the built-in 10/100 as a bridge to each port, correct? I don't need a full config example so much (but it would be nice) as I want to be pointed in a direction towards docs about what I am doing, be it bridging or something else.
Also, I would like to utilize the IOS IDS features, any advice here is also appreciated.
Thanks!
Bronze
Re: 1721 with WIC-4ESW Help
Please note that only ONE WIC-4ESW is supported on Cisco 1700 series routers at present. Refer this link for this information.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5413/prod_release_note09186a00801c46b3.html#97217
For your situation go for DMZ with Cisco IOS firewall. Please go through the following links how to configure DMZ and IDS with Cisco IOS firewall.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1830/products_feature_guide09186a008008796f.html
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca7c6.html
Anonymous
N/A
Did you get any good answer ?
I'm trying to do the same but only with one wic.
please contact me to etourjeman@vicon-cctv.com.
really appreciate it.
Erez
153
