1751 with a WIC-1ENET (dot1q encapsulation problems)
Using IOS release 12.1(5)YB1 I can define dot1q sub-interfaces on the WIC-1ENET.
When I upgrade to 12.2(2)XQ1 I can no longer do this. The encapsulation dot1q command is not recognised.
Does anyone know if this is an outstanding bug? If not a bug why is this not supported anymore??
1 REPLY
Re: 1751 with a WIC-1ENET (dot1q encapsulation problems)
It’s supposed to be there according to the docs on CCO. Maybe it’s only included in the PLUS feature set or something. Your TAC rep should be able to point you to the correct image.
214
