1841 and 4 port Switch
CSCO10566640
I have some 1841 routers in a network, each has a 2 port E1 WAN module and a 4 port Ethernet Switch module. If I create VLANs on the switch module - what do I do for a trunk port. I want my VLAns to go out on the WAN port to another router. Can the E1 WAN port be a trunk port between 2 routers that have switching modules in them. I have read the config guide but it doent help
many thanks
Bob
17 Replies 17
You certainly don't...but you can (with the bridging config I mentioned earlier). However, that is very inefficient...
Paresh
Thanks for your help - I will try this on Monday with the equipment.
regards
Bob
Worked a treat - problem solved - many thanks
