2500 IOS and MBGP problem
my IOS file is c2500-js-l.122-21a.bin
and cisco said the IOS support MBGP, but no.
my configuration is
ip multicast-routing
router bgp xx
nei 1.1.1.1 remote yy ?
when I enter ?, only <cr> there, no "nlri",
any ideas?
Re: 2500 IOS and MBGP problem
This CLI has been replaced by the new address-family model. Here's an example.
router bgp 1
no synchronization
bgp log-neighbor-changes
network 1.0.0.0
neighbor 2.2.2.2 remote-as 1
neighbor 2.2.2.2 update-source Loopback0
no auto-summary
address-family ipv4 multicast
neighbor 2.2.2.2 activate
exit-address-family
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
thanks a lot.
I can not use "multicast" and "unicast" together, this is right? because I use "neighbor 2.2.2.2 remote 1 nlri multicast unicast" before. now, I should configure "multicast" and "unicast" seperately?
just like
Address-familiy ipv4 multicast
xxxxxxxxxxxx
address-family ipv4 unicast
yyyyyyyyyyyy
right ?
ask one more question, why I can not use IOS 12.3.6 for the 2500, it seems the IOS file is so big(exceed size)
Thanks again
You are correct. You have to configure a separate address-family statement for multicast and unicast (or VRF also available in the version you are running).
Regarding your other question, the minimum requirements to support 12.3(6) IP Only Feature set is 12MB DRAM and 16MB Flash. So unless you have less memory than that installed on your router, you should be fine.
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
for the unicast, it is default, so I think I don't need to configure that, right?
For the IOS,
c2500-is-l.123-6.bin size is 16544 KB
the Flash is 16384K
All my 2500 are 16/16, and the IOS of 12.3.6 didn't work
That's correct, IPv4 is the default and doesn't need to be explicitly configured as seen below:
router bgp 1
exit-address-family
R1#sh ip bgp nei
BGP neighbor is 2.2.2.2, remote AS 1, internal link
BGP version 4, remote router ID 2.2.2.2
BGP state = Established, up for 00:00:07
Last read 00:00:07, hold time is 180, keepalive interval is 60 seconds
Neighbor capabilities:
Route refresh: advertised and received(old & new)
Address family IPv4 Unicast: advertised and received
Address family IPv4 Multicast: advertised and received
Although not explicitly specified, ipv4 unicast show as advertised in the neighbor capabilities of the output of the "sh bgp nei" command.
If you don't need the default ipv4 unicast address-family, you can use the following command:
router bgp 1
no bgp default ipv4-unicast
R1#sh ip bgp nei
BGP state = Established, up for 00:00:25
Last read 00:00:25, hold time is 180, keepalive interval is 60 seconds
As you can see the address-family ipv4 unicast has been removed from the capability exchange.
As far as the size of 12.3(6) IP Plus is concerned, you are right the requirements should be greater than 16MB of Flash memory. I will make sure that I follow up with the CCO team so that they get the minimum requirement changed for this image.
Hope this helps,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Thanks a lot.
The MBGP,MSDP,SSM are in the real network now?
I have seen MBGP and MSDP in numerous designs over the last two to three years. I'm sure that there are people out there using SSM but is not as commonly seend as the other two protocols.
BTW: I already have an internal case to get the flash memory requirement change on CCO for 12.3(6) IP Plus.
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
95
