02-12-2002 10:43 AM - edited 03-01-2019 08:26 PM
why my router always boots from rom rather than from flash.config reg is correct but once we try to access flash as "sh version" or "try to copy flash contents" shows it is a read only.the same error is received when i try to load IOS from a tftp server
pls give me a solution
02-12-2002 02:10 PM
how much flash ? If you have 16 meg, then
partition flash 2 8 8
the "side" with the ios in it remains read only,
the other side will be read write.
what do your boot statements say ?
02-12-2002 07:32 PM
here is the message i received
Router(boot)#sh ver
IOS (tm) 3000 Bootstrap Software (IGS-BOOT-R), Version 11.0(10c)XB2, PLATFORM SP
ECIFIC RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1996 by cisco Systems, Inc.
Compiled Mon 05-Oct-98 10:52 by jaturner
Image text-base: 0x01010000, data-base: 0x00001000
ROM: System Bootstrap, Version 11.0(10c)XB2, PLATFORM SPECIFIC RELEASE SOFTWARE
(fc1)
Router uptime is 1 minute
System restarted by power-on
Running default software
cisco 2500 (68030) processor (revision L) with 6144K/2048K bytes of memory.
Processor board ID 22647777, with hardware revision 00000000
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
2 Ethernet/IEEE 802.3 interfaces.
2 Serial network interfaces.
32K bytes of non-volatile configuration memory.
8192K bytes of System flash (Device not programmable)
Router(boot)#sh flash
System flash directory:
No files in System flash
[0 bytes used, 8388608 available, 8388608 total]
Router(boot)#copy tftp flash
ERR: Device in READ-ONLY state
02-13-2002 12:25 PM
Hi Prasanth,
Flash memory provides write protection against accidental erasing or reprogramming.
Some platforms have a write-protect jumper which can be removed to prevent reprogramming of Flash memory. You must install the jumper when programming is required.
Some platforms have write protect switched on Flash memory cards that you can use to protect data. You must set the switch to unprotected to write data to the Flash memory card.
Refer to your hardware documentation for information on security jumpers and write protect switches.
Good Luck,
Javed
02-17-2002 12:20 PM
It seems that there is no file in the flash, so even though the specified register entry is correct, the router will not load from the flash.
Try using the following syntax from the ROM Monitor. IF it works it will help you load a copy of flash. I assume that you do have a back-up or a copy of flash that is compatible with this router. Just type the following commands on the left with a value as described on the right.
IP_ADDRESS= ip address of the router
IP_SUBNET_MASK= SUBNET MASK OF THE NETWORK
DEFAULT_GATEWAY= IP ADDRESS OF THE DEFAULT GATEWAY
TFTP_SERVER= IP ADDRESS OF THE TFTP SERVER
TFTP_FILE= TFTP FILE NAME
THEN type tftpdnld, and the above information will be executed.
I hope it was helpful.
Amit Sonik
