Community Member
2501 does not keep configuration
2501, IOS 12.0, config, save and show run: configuration is correct.
Shutdown and restart 2501:
It kept go to the intial config,
all the configuration before was lost.
1 REPLY
Anonymous
N/A
Re: 2501 does not keep configuration
It is possible that the Configuration register value is set to Ignore NVRAM. Reset this and check
154
