Community Member
2502 seems to lock up?
I just got 2 - 2502 routers off of eBay and after starting them up it seems to load up normally until it locks up. I can't figure out what's going on and it won't let me CTRL+BREAK or anything that would allow me to reconfigure the router. Can anyone help me with this, or atleast point me in the right direction? I've pasted a copy of what I get from the router.
Also, where can I find an updated IOS since I obviously did not buy my routers from cisco?
System Bootstrap, Version 5.2(8a), RELEASE SOFTWARE
Copyright (c) 1986-1995 by cisco Systems
2500 processor with 14336 Kbytes of main memory
F3: 7370472+108420+286116 at 0x3000060
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS s
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) 2500 Software (C2500-AINR-L), Version 11.2(17), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Mon 04-Jan-99 17:55 by ashah
Image text-base: 0x03038204, data-base: 0x00001000
cisco 2500 (68030) processor (revision L) with 14336K/2048K bytes of memory.
Processor board ID 02968667, with hardware revision 00000000
Bridging software.
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
1 Token Ring/IEEE 802.5 interface(s)
2 Serial network interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read ONLY)
Press RETURN to get started!
%LINK-3-UPDOWN: Interface Serial0, changed state to down
%LINK-3-UPDOWN: Interface Serial1, changed state to down
%LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback0, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0, changed state to down
%LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1, changed state to down
%LINEPROTO-5-UPDOWN: Line protocol on Interface TokenRing0, changed state to dow
n
%SYS-5-CONFIG_I: Configured from memory by console
%SYS-5-RESTART: System restarted --
%LINK-5-CHANGED: Interface Serial1, changed state to administratively down
%LINK-5-CHANGED: Interface TokenRing0, changed state to administratively down
1 REPLY
VIP Purple
Re: 2502 seems to lock up?
what are your configuration register settings ? Make sure it is 0x2102. To change it, hit Ctrl+Break within 10 seconds after booting the router, this will get you into ROMMOM mode. Change the configuration register to 0x2102 and reload the router.
HTH,
GP
74
