02-20-2004 11:16 AM - edited 03-02-2019 01:45 PM
We are currently using an ASM-CS comm server with 16 Async lines to connect to several 500-CS comm servers and 2509 access servers. The connections are via AT&T/Lucent secure data 1910 modems (STU-III) over leased/dedicated POTS lines. The network is isolated.
We are trying to replace the ASM-CS with two 2509 access servers. I am successful connecting 2509 to 2509, but am unable to connect 2509 to 500-CS.
Config (minus unused ints) for the source 2509 is:
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
service internal
service old-slip-prompts
hostname cs-hub
enable password <removed>
ip subnet-zero
interface Ethernet0
ip address 89.10.1.1 255.255.0.0
ip helper-address 89.11.255.255
interface Async1
bandwidth 38400
ip address 89.17.251.251 255.255.0.0
ip tcp header-compression
ip ospf cost 2604
ip ospf retransmit-interval 1
keepalive 10
async dynamic routing
async mode interactive
router ospf 89
log-adjacency-changes
network 89.10.0.0 0.0.255.255 area 0.0.0.10
network 89.134.0.0 0.0.255.255 area 0.0.0.134
network 0.0.0.0 255.255.255.255 area 0.0.0.0
ip classless
ip route 89.134.0.0 255.255.0.0 89.17.252.252
no ip http server
line con 0
line 1
modem InOut
no exec
transport preferred none
transport input all
autoselect slip
speed 38400
flowcontrol hardware
line 2 8
line aux 0
line vty 0 4
password <removed>
login
end
Config for the corresponding 500-CS is:
version 9.1
hostname cs-9bs
enable-password <removed>
ip routing
interface Ethernet 0
ip address 89.134.128.1 255.255.255.0
no lat enabled
no mop enabled
interface Async 1
ip address 89.17.252.252 255.255.0.0
router ospf 134
ip name-server 255.255.255.255
snmp-server community manager RW
snmp-server host 89.10.130.56 manager TTY
line vty 0 4
login
line con 0
line 1
no exec
flowcontrol hardware in
flowcontrol hardware out
modem inout
txspeed 38400
rxspeed 38400
slip routing
slip address 89.17.252.252 255.255.0.0
slip header-compression on
slip dedicated
line 2
line 3
line 4
line 5
line 6
line 7
line 8
line vty 0
password <removed>
line vty 1
password <removed>
line vty 2
password <removed>
line vty 3
password <removed>
line vty 4
password <removed>
end
I've searched the forums for 500-CS and connection problems, and have tried several different config commands, but still no connection from 2509 to 500CS.
Any ideas would be greatly appreciated.
Thanks in advance!
02-26-2004 08:10 AM
Try to use software flow control. And also try to use "transport input telnet" command.
03-03-2004 09:09 AM
Thanks for the suggestion. I gave both a try, but to no avail.
I have been successful connecting between the 2509 and 500CS. Seems one of the phone networks we use was the culprit.
From within the 2509 console I am able to ping in/out the async port to/from the 500CS, and in/out the ethernet port to/from a computer on the LAN.
However I am still unable to ping all the way through from Ethernet LAN computer to remote 500 CS via the async port.
Thanks again for the help.
Al
03-03-2004 09:09 AM
Al
