2521 as small frame switch (lab)
Hey all, I have a rather basic question. Am setting up a lab for messing with, and wanted help on configuring a 2521 as a small 4 port frame switch.
I followed instructions in Cisco TCP/IP Routing Profesional Reference (man, that book has been on my desk a LONG time) and have the following:
frame-relay switching
interface serial 0
no ip address
encapsulation frame-relay
clockrate 1000000
frame-relay intf-type dce
frame-relay route 17 interface serial 1 18
interface serial 1
no ip address
clockrate 1000000
frame-relay route 18 interface serial 0 17
Now for the dumb part - how should I configure serial ports 2 and 3? Getting a little confused on the frame-relay route statements (I guess I should draw it out).
1 REPLY
Re: 2521 as small frame switch (lab)
You would configure them the same way assuming you are hanging some other routers out there.
What you have above is a setup where you can hang a router off of serial 0 and serial 1 and route traffic between them so assuming you are planning on doing the same on serial 2 and 3, configure them similarly.
97
