2524 Ethernet WIC module?
Can someone tell if the the 2524 will support a WIC Ethernet module? If it does, could I get a link or part number.
I need to have an additional Ethernet port and the 2524 only has 1 Ethernet port...
Thanx in advance....
1 REPLY
Re: 2524 Ethernet WIC module?
WIC slot on 2500 will not support ethernet interfaces. So if you want two ethernet port on it, you need 2514 router. Pl. check this url for 2500 series product line
http://www.cisco.com/warp/public/63/arch_2500_5750.shtml
156
