2600 Configuration help
I have an old 2600 router that I need to configure. I have all the needed software but I cannot remember the enable password. Is there a way to clear the password so I can get started?. If not it would be ok to clear the config of the router. It is not being used online at all.
1 ACCEPTED SOLUTION
Re: 2600 Configuration help
Here is the link for the password recovery procedure.
You will need to login to CCO to access the site.
Cheers
-Joe
http://www.cisco.com/warp/customer/474/pswdrec_1600.shtml
Cheers
-Joe
Bronze
84
