2600 Flash Memory smaller after erase?
I have noticed this on a few routers recently - If I have a 16MB Flash SIMM,
and format and upload the image to it using the ROM Monitor, I get the full
space of the flash. However, if I use the erase flash command in the IOS
itself, I mysteriously lose 512K of it, for a 15872K total instead of
16384.. The show ver command still shows "16384K bytes of processor board
System flash (Read/Write)" Repeating the procedure from ROM Monitor
gave me the space back. (Slightly more cumbersome!)
I tested this with an older IOS image (12.0-4 i believe) and the IOS format
gives you all the space.
Here is a sample of the results on a router that was upgraded using the IOS
erase command:
>sh flash all
Partition Size Used Free Bank-Size State Copy Mode
1 15872K 14236K 1635K 8192K Read/Write Direct
System flash directory:
File Length Name/status
addr fcksum ccksum
1 14577976 c2600-ik9o3s3-mz.122-13.T.bin
0x40 0x751D 0x751D
[14578040 bytes used, 1674888 available, 16252928 total]
16384K bytes of processor board System flash (Read/Write)
Chip Bank Code Size Name
1 1 89A0 2048KB INTEL 28F016SA
2 1 89A0 2048KB INTEL 28F016SA
3 1 89A0 2048KB INTEL 28F016SA
4 1 89A0 2048KB INTEL 28F016SA
1 2 89A0 2048KB INTEL 28F016SA
2 2 89A0 2048KB INTEL 28F016SA
3 2 89A0 2048KB INTEL 28F016SA
4 2 89A0 2048KB INTEL 28F016SA
and another 2611 router, that was upgraded using the ROM Monitor upgrade
procedure:
1 16384K 14236K 2147K 8192K Read/Write Direct
addr fcksum ccksum
0x40 0x751D 0x751D
[14578040 bytes used, 2199176 available, 16777216 total]
1 1 01AD 2048KB AMD 29F016
2 1 01AD 2048KB AMD 29F016
3 1 01AD 2048KB AMD 29F016
4 1 01AD 2048KB AMD 29F016
1 2 01AD 2048KB AMD 29F016
2 2 01AD 2048KB AMD 29F016
3 2 01AD 2048KB AMD 29F016
4 2 01AD 2048KB AMD 29F016
Its not just 16MB Flash memory either, I've tested this on 8MB modules, and
end up with 7.5 megs on those too.
Is there some new feature in the later IOS's that I'm not aware of that
explains this - does this seem normal to anyone else?
Any input appreciated, this seems quite odd to me.
Thanks in advance.
VIP Purple
Re: 2600 Flash Memory smaller after erase?
afer you have erased the flash, issue the command ' squeeze flash:', that might help.
Georg
Hmm.. Doesn't get me the space back, but you seem to be on the right track. If I issue this to flash memories formatted with IOS, the squeeze command works. However, on the one formatted with ROMMON that gives me all the space, i get the following error:
Router#squeeze flash:
Squeeze operation may take a while. Continue? [confirm]
first create squeeze log by erasing the entire device
%Error squeezing flash (Unknown error 0)
So is that wasted space occupied by the squeeze log then?
I've since tried this on a 3620's 16MB PCMCIA flash card, and noticed that I lose 256K of those as well after erasing...
110
