Webcast-Catalyst9k
2600 ISDN Backup Regular Dailing Problem
I have a 2600 hundred with a leased line connected via serial and a ISDN dialer backup. Everything has been working well until I got the telephone bill and noticed that the router seems to be dialing the backup almost every minute for a very short call.
Can anyone give me advice as to what to look for to track down what could be causing this and what debug commands I could use?
Many thanks
Rob
Re: 2600 ISDN Backup Regular Dailing Problem
Can you post the config for the 2600 router?
Yes, glad to post it as follows. Thank you for helping!
Rob
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname *****
enable password *********************
username ***** password ******
ip subnet-zero
no ip domain-lookup
isdn switch-type basic-net3
interface FastEthernet0/0
description connected to EthernetLAN
ip address 151.x.x.x.255.0.0
duplex auto
speed auto
interface Serial0/0
description connected to B
backup delay 15 60
backup interface Dialer1
ip address 10.152.x.x.x.255.252
encapsulation ppp
interface BRI0/0
no ip address
encapsulation ppp
dialer rotary-group 1
no cdp enable
interface Dialer1
ip address 10.152.2.1 255.255.255.252
encapsulation ppp
no ip split-horizon
dialer in-band
dialer map snapshot 1 name B broadcast
dialer map ip 10.152.2.2 name B broadcast 0******
dialer hold-queue 10
dialer load-threshold 10 outbound
dialer-group 1
snapshot server 15 dialer
no cdp enable
ppp authentication chap
ppp multilink
router rip
version 2
network 10.0.0.0
network 151.151.0.0
no auto-summary
ip classless
no ip http server
ip pim bidir-enable
dialer-list 1 protocol ip permit
snmp-server community public RO
line con 0
exec-timeout 0 0
login
line aux 0
line vty 0 4
login
no scheduler allocate
end
If your DDR is dialing up every minute, you should run debug dialer. That will show the dialing cause.
Purple
Also to me it looks like your have dialer load threshold set awfully low , you might want to consider making this a higher number , this might be triggering it also , but to determine which ip is causing the dial you the debug dialer command as indicated in the previous post .
Looks like you've got snapshot routing configured here.... Any need for it? Check out CCO documentation regarding snapshot routing.
Hope this helps.
Daniel
1) Check the need for snapshot routing.
2) Add "passive-int b0/0" at your router rip.
3) Relate your dialer-list to the kind of traffic that you want to be considered as interesting, via an acl.
Do you have an access list set up so that only significant traffic will cause an isdn call to initiate. We use the following format:
access-list 100 deny eigrp any any
access-list 100 deny ip host 255.255.255.255 any
access-list 100 permit ip any
dialer-list 1 protocl ip list 100
You might want to substitute the eigrp with rip.
139
