I am having a problem which I think is due to the trunking. I have multiple vlans on each router trunked down to the 2950. One vlan is set up as a network between the two routers using a wireless solution. From router to router I can ping the interfaces, but I can't go from client to client on opposite sides of the wireless. I am using IGRP and all the information is found on each side.
2600 -> 2950 <--> 2950 <- 2600
Any help is greatly appreciated.
