Community Member
2600 upload speed problem
I have a 2600 which has 2 wic dsu T1 cards in it. I have use the ip load balancing comand on each serial interface. I removed ip cef, which brought the speed up alot on 1 T1 but the other is still the same.
1 parent T has 2600 download and 1300 upload and the other Child T has 2600 download and 900 upload.
I need to get 2600 both ways on both T's
Here is the config for the serial ports on the router:
interface Serial0/0
description Parent T to AT&T
ip address x.x.x.x 255.255.255.252
ip load-sharing per-packet
encapsulation ppp
load-interval 30
no fair-queue
interface Serial0/1
description Child T to AT&T
encapsulation ppp
load-interval 30
no fair-queue
1 REPLY
Silver
Re: 2600 upload speed problem
Enter no ip route-cache in the interfaces which are used to for load balancing , If it does not work try load balancing with per destinaton , that can improve the condition.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/switch_c/xcprt2/xccefc.htm
105
