2600 with PRI card connecting to BRI with Shiva Access Ports
I need to setup a 2600 on a PRI circuit to statically route seperate IP networks to branch offices where the remote sites are both on occasion dialing in and being dialed from the main site.
The remote sites are using Shiva Access Ports and were previsouly configured to dial into a central Shiva Mezza (which has died suddenly).
I've tried some of the suggested configs from the cisco site but cant get either end to make a connection. The 2600 can do a link test etc so I know it's talking to the ISDN switch at a basic level but apart from that I'll readily admit I'm way out of my depth :o)
Has anybody tried this arrangement before and could share some sample configs or tips? Help! Thanks.
Silver
Re: 2600 with PRI card connecting to BRI with Shiva Access Ports
Need to know what your present config is, will need to configure inline with the below sample config.
sh run / sh ver / sh isdn status outputs will be useful.
http://www.cisco.com/warp/public/793/access_dial/pri_dialin_6435.html
Can you please post the outputs of the following debugs (for call in or out)
deb isdn q931 / deb ppp nego / deb dialer
Thanks, Mak.
Thanks for the reply Mak, here's the info you're after.
sh run:
Building configuration...
Current configuration : 1309 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname edsr01
enable secret 5 ******************************
enable password 7 **************
username bowtest password 7 ******************
ip subnet-zero
ip domain-name nhs.uk
isdn switch-type primary-net5
controller E1 1/0
pri-group timeslots 1-8,16
interface FastEthernet0/0
ip address 172.16.192.1 255.255.0.0
ip access-group 100 in
duplex auto
speed auto
interface Serial1/0:15
no ip address
no cdp enable
interface Dialer1
description connected to bowtest
no ip address
encapsulation ppp
no ip split-horizon
dialer in-band
dialer map ip 172.22.192.1 name bowtest broadcast 12345678912
dialer-group 1
snapshot server 15 dialer
no cdp enable
ppp authentication chap
ip classless
ip http server
ip pim bidir-enable
access-list 100 deny udp any any eq snmp
access-list 100 deny udp any any eq snmptrap
access-list 100 permit ip any any
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
line con 0
login
line aux 0
login
transport input all
line vty 0 4
login
end
sh ver:
IOS (tm) C2600 Software (C2600-I-M), Version 12.2(8)T5, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Fri 21-Jun-02 08:50 by ccai
Image text-base: 0x80008074, data-base: 0x80A2BD40
ROM: System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
edsr01 uptime is 8 minutes
System image file is "flash:c2600-i-mz.122-8.T5.bin"
cisco 2610XM (MPC860P) processor (revision 0x100) with 26624K/6144K bytes of mem
ory.
Processor board ID JAD064308A4 (3616868118)
M860 processor: part number 5, mask 2
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
9 Serial network interface(s)
1 Channelized E1/PRI port(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
sh isdn status:
Global ISDN Switchtype = primary-net5
ISDN Serial1/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x800000FF
Number of L2 Discards = 0, L2 Session ID = 0
Total Allocated ISDN CCBs = 0
deb isdn q931:
ISDN Q931 packets debugging is on
deb ppp nego:
PPP protocol negotiation debugging is on
deb dialer:
Dial on demand events debugging is on
113
