2610 ISDN PROBLEM
Hi everyone !
I have this problem: in a Central Site I configured a Cisco 2610 router connected with a 2 ISDN device (s/t). In a 3 remote site I have connected 3 (one for each site) cisco 801 router. My problem is that when a Cissco 801 call a Central site the 2610 ansew only to 1 dialer profile (number 2) but with number 1 and 3 dialer profiles it does't answer.
Could you verify if my configuration is ok ?
Thank you
EB
Building configuration...
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname VENEZIA_01
enable password 7 030752180500
username LIDO_01 password 7 071B245F5A
username MURANO_01 password 7 09584B1A0D
username CAVALLINO_01 password 7 044F0E151B
ip subnet-zero
no ip domain-lookup
isdn switch-type basic-net3
interface Ethernet0/0
description connected to EthernetLAN
ip access-group 101 in
no ip directed-broadcast
interface BRI1/0
description connected to LIDO_01,CAVALLINO_01
no ip address
encapsulation ppp
dialer pool-member 1
dialer pool-member 3
isdn answer1 0412770090
interface BRI1/1
description connected to MURANO_01
no ip address
encapsulation ppp
dialer rotary-group 2
isdn answer1 0412771181
no cdp enable
interface BRI1/2
no ip address
shutdown
interface BRI1/3
no ip address
shutdown
interface Dialer1
ip address 172.16.1.1 255.255.255.252
encapsulation ppp
no ip split-horizon
dialer remote-name LIDO_01
dialer string 10770412420319
dialer hold-queue 10
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap
interface Dialer2
ip address 172.16.2.1 255.255.255.252
encapsulation ppp
no ip split-horizon
dialer in-band
dialer map ip 172.16.2.2 name MURANO_01 broadcast 10770415274833
dialer-group 1
no cdp enable
interface Dialer3
description connected to CAVALLINO_01
ip address 172.16.3.1 255.255.255.252
encapsulation ppp
no ip split-horizon
dialer remote-name CAVALLINO_01
dialer string 10770415302226
dialer pool 3
dialer-group 1
no cdp enable
ip classless
ip route 192.168.2.0 255.255.255.0 172.16.1.2
ip route 192.168.3.0 255.255.255.0 172.16.2.2
ip route 192.168.4.0 255.255.255.0 172.16.3.2
access-list 101 deny udp any range netbios-ns netbios-ss any
access-list 101 deny tcp any range 135 139 any
access-list 101 permit ip 192.168.1.0 0.0.0.255 192.168.0.0 0.0.255.255
access-list 101 permit ip any any
dialer-list 1 protocol ip permit
snmp-server community public RO
line con 0
exec-timeout 0 0
password 7 01100F175804
logging synchronous
login
transport input none
line aux 0
line vty 0 4
login
no scheduler allocate
end
Bronze
Re: 2610 ISDN PROBLEM
I'm not certain that you need to even use dialer profiles here (you could put everything under a single dialer rotary group), but at any rate you should either add ppp authentication to BRI1/0, or add "dialer caller" to Di1 and Di3, with the CLID for the respective users.
Thank you very much for you patience.
I have to add either ppp hostname and ppp password under bri1/0 ?
Under Dialer 1 and 3 I have only to add dialer number fopr the respective router callin in ?
Thank you
Ermanno Boldi
I'm not understanding what you mean for "put everything in a single dialer rotary gorup): could you make me an example ?
Thank you very much
Ermanno
Be advised, you should never post full/ production configs If your configuration is a production config, with the information you provided someone could easliy gain access to your network.
110
