Community Member
2610XM BRI Incoming call
Dear All,
I am having a 2610XM. When I dial to it from another router either 3640 or any I got conected but I am unable to do any communication. While same 3640 is able to do communication when i connect that 3640 to any other router. I am attaching the show runn config of 2610XM in txt format.
Silver
Re: 2610XM BRI Incoming call
It will be useful to the see the config on the calling router as well.
When you so the call gets connected, what do you see in the "sh isdn active" or "sh user" commands.
Can you run the following debugs when the 2610xm is receiving a call in:
deb isdn q931 / deb ppp nego.
Thanks, Mak.
Community Member
Dear Mak First of thanx for ur reply.
I am attaching two files one (Ahmd-Start.txt) contains config of calling router and another file (Surat-debugg.txt) containing Debugg messages and below that file is the output of sh isdn active and sh user commands.
Community Member
Dear All,
One thing more, its not the problem with the calling router, as when I connect the same 2610xm from a Windows 2000 machine (Pre defined IP)then also it gets connect but I am unable to communicate with the machines which are behind the router.
Any suggestions or queries are highly appreciated.
Anis
Community Member
Dear All (CCNP< CCIE etc.)
Reply me pls. Its Cisco's discussion Forum and not any local companies. If u all require any information, I am ready to give but helpe pls.
Anis
91
