2610XM router Ethernet interface
Do the Ethernet interfaces on the new 2600XM routers support 100Mb-Full Duplex settings? I think the old platform did not support this, but I wanted to confirm.
Jericho
Re: 2610XM router Ethernet interface
Try going into the interface:
config t
interface F0/0 (for example) and try the command
speed 100
duplex full
If the router accepts the command then the interface will run at 100-Full
I don't have the router yet, it's being considered for purchase. I'm asking because a felllow colleague mentioned an issue with setting the interface on the previous 2600 platform.
thanks
I just looked at one of our "older" 2620 and we are running 100Mb/s Full-Duplex on the ethernet interface.
Yes, it´s possible. i´m working recently with that and i could check it. the new 2600XM routers has a FastEthernet Interface and 100Mb-Full Duplex settings.
regards nad good luck with your purchase.
AS
235
