2611, 3620 routing problem
I have a 3620 directly connected to a 2611, all connections are up and running correctly and each router can ping the directly connected interface of its neighbour. The problem I have is that I cannot ping from a client on the LAN side of the 2611 to the 3620. RIP is set up, though the 3620 uses RIP V2. Default routing is also set up on each router to allow access to the internet.
I can ping from a client node of 192.168.0.101 to e0/1 192.168.0.100 and also ping to e0/0 195.195.15.2 but thats it! I cannot ping on to the next hop of 3620 e1/3 192.168.100 even though if I ping from the 2611 router CLI I can ping the 3620 e1/3 192.168.100. What gives?
  • Other Network Infrastructure Subjects
Re: 2611, 3620 routing problem
the configs go like this:
2611 -
hostname TestLab
enable secret xxxxx
ip subnet-zero
interface Ethernet0/0
ip address x.x.x.2 255.255.255.248
no ip directed-broadcast
full-duplex
interface Ethernet0/1
ip address 192.168.0.100 255.255.255.0
router rip
network 192.168.0.0
network 195.195.15.0
ip classless
ip route 0.0.0.0 0.0.0.0 195.195.15.1
no ip http server
line con 0
password
login
transport input none
line aux 0
password
login
line vty 0 4
password
login
end
3620 -
interface FastEthernet0/0
no ip address
speed 100
full-duplex
interface FastEthernet0/0.1
description ****Connection to VLAN 1****
encapsulation dot1Q 1 native
ip address 10.4.1.1 255.255.255.0
ip access-group 101 out
no ip redirects
interface FastEthernet0/0.2
description ****Connection to VLAN 2****
encapsulation dot1Q 2
ip address 10.3.1.1 255.255.255.0
ip access-group 102 out
no ip redirects
interface FastEthernet0/0.3
description **** Connection to VLAN 3 ****
encapsulation dot1Q 3
ip address 10.5.1.1 255.255.255.0
interface FastEthernet0/0.4
description ****Connection to VLAN 4****
encapsulation dot1Q 4
ip address 10.6.1.1 255.255.255.0
interface Ethernet1/0
description ****Connection to Internet****
ip address 10.1.1.1 255.255.255.0
half-duplex
interface Ethernet1/1
description **** Link to ISA Server ****
ip address 10.2.1.1 255.255.255.0
half-duplex
interface Ethernet1/2
no ip address
shutdown
half-duplex
interface Ethernet1/3
ip address x.x.x.1 255.255.255.248
full-duplex
router rip
version 2
passive-interface Ethernet1/0
network 10.0.0.0
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.1.2
no ip http server
Silver
On the 3620 can you paste in a sh ip route 192.168.0.101
I do not think you are talking rip between the 2600 & 3600 , you need to enable v2 on the 2611
It looks like you're right. I did a show ip route 192.168.0.101 and its not in the routing table. The 2611 is using an old IOS so I'll have to update the image. I had hoped that RIP V2 would be backward compatible, obviously not though!
Silver
do you need rip v2 ? It looks like you only have a few networks
well is there a way of disabling RIP v2 on the 3620?
Silver
yes you can specify under the interface what kind of Rip updates you want to send an/or receive
I beleive the commands are
send rip v1
send rip v2
receive rip 1
receive rip v2
210
