2611 max mem?
what is the maximum amout of memory a cisco 2611 can have inside? and how big can the sticks be? can it accept 128mb sticks? or just 64?
1 ACCEPTED SOLUTION
Re: 2611 max mem?
First of all Cisco doesnt support non Cisco memory chips, if any trouble happens and you open a case for support.
I have a 2610 with me, which has PC DIMM with 50 pins on either side. I doubt if the PC DIMM with 168 pin will get in there....
Re: 2611 max mem?
2611 (normal) can take only max 64 mb of ram, but you can put 128 on a 2611XM series.
Re: 2611 max mem?
i have heard before that you can put pc memory into a router. i know of some people that have done it and it seems to work fine. would PNY 64MB ECC PC100 SDRAM 8x72 168 Pin DIMM work in a 2611?
Re: 2611 max mem?
81
