2611 with a T1 and Cable
I have a 2611 connected to a T1 on the WAN port , a ethernet connection to a cable router on one of the ethernet ports and a LAN connection on the seconsd ethernet port. The Cable line has a dynamic ip address assigned to it while the T1 has a static IP address. can I have the router automatically switch over to the T1 line if I lose my cable connection , or switch to the cable line if I lose my T1 connection. The T1 is Frame relay connected to database servers and the internet. the cable connection is for internet use
Re: 2611 with a T1 and Cable
Have you tried the "backup interface" command?
also you can try using 2 static default routes with different metrics towards the 2 interfaces...........
hi,
you can specify the ethernet interface of yr router in which the cable line lands , as a backup interface of your serial line. you need to specify this in yr serial interface and need to give the delay timings.
Ramesh
92
