2612 TokenRing to Ethernet bridging, need help
Hi All
I have 1 2612 with a tokenring lan on one side and a ethernet on the other side. I have tried to follow several examples from the cisco site without any sucsess. Can anyone help me? This is my config so far, what am I missing here?
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
hostname Router
enable secret 5 ****************************
enable password ******
ip subnet-zero
source-bridge ring-group 10
source-bridge transparent 10 11 1 1
interface Ethernet0/0
no ip address
half-duplex
bridge-group 1
interface TokenRing0/0
no ip address
ring-speed 16
source-bridge 1 1 10
source-bridge spanning
ip classless
ip http server
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
bridge 1 protocol ieee
line con 0
line aux 0
line vty 0 4
password ******
login
end
Rgds,
Svein
Re: 2612 TokenRing to Ethernet bridging, need help
Which protocols do you try to bridge - layer 2 or/and layer 3 protocols (ip/ipx).
If you bridging ip, you can try irb with bitswapping of layer 3. Be aware of RIF.
Hope this gives you some ideas.
Brg,
Steinar
There should a command along the lines of
bridge 1 bitswap-layer3-addresses
Thanks for the help, but it still doesnt work. From our 2612 and to the Tokenring side we have a IBM8272 Tokenring Switch which everything is connected to. So I'm wondering if there is anything that I'll have to do in this switch as well?.
BTW i have added these lines in global mode:
bridge irb
/Svein
Sorry for delayed answer.
It is not good to have both srtlb and irb since it could generate a loop.
You should try to use a sniffer to see what is happening.
Steinar.
149
