2620 with NM-16a - Can not reverse telnet to attached cisco console
I have a 2620 with a NM-16A adapter which I would like to use as terminal
server and connect to the console ports of my other Cisco devices. I had
this set up on a 3640 with the same adapter and it worked fine. I thought
it was a waste of a router so I moved it to a 2620. Basically, when I
reverse telnet to a device attached to the NM-16A on the 2620, my screen
goes to "open" and then will not return any info or accept any other
commands other than the break out sequence.
(2) points of interest may be:
1- The only difference I can see between the show line x command output on the 3640 and 2620, while the reverse telnet session is open or stuck open, is the CTS indicator on the 'Modem Hardware State'. On the 3640 output has an asteric following it where the 2620 does not. IE: 3640 = CTS* and 3620 = CTS. I am not sure if that has any significance. The 3640 is the one that works.
2- After I 'disconnect x' I have to 'clear line' before I can try again.
I have tried 3 different IOS versions, all of which are supported.
I have pasted the output where I am stuck and a copy of the show line x command output while stuck.
OUTPUT =====================================================
Router-1>telnet device-1
Trying device-1 (192.168.0.1, 2033)... Open <--(Stuck Here and can only
CTR+SHF+6, x to break out).
Line 33, Location: "", Type: "ANSI"
Length: 40 lines, Width: 80 columns
Baud rate (TX/RX) is 9600/9600, no parity, 2 stopbits, 8 databits
Status: Ready, Connected, Active
Capabilities: EXEC Suppressed
Modem state: Ready
Modem hardware state: CTS DSR DTR RTS
Special Chars: Escape Hold Stop Start Disconnect Activation
^^x none - - none
Timeouts: Idle EXEC Idle Session Modem Answer Session Dispatch
00:30:00 00:20:00 none not set
Idle Session Disconnect Warning
00:15:00
Login-sequence User Response
00:00:30
Autoselect Initial Wait
not set
Modem type is unknown.
Session limit is not set.
Time since activation: 00:04:26
Editing is enabled.
History is enabled, history size is 10.
DNS resolution in show commands is enabled
Full user help is disabled
Allowed input transports are telnet.
Allowed output transports are pad v120 telnet rlogin.
Preferred transport is telnet.
No output characters are padded
No special data dispatching characters
Thank you so much for any help. I have been working on this for a long time.
1 REPLY
Bronze
Re: 2620 with NM-16a - Can not reverse telnet to attached cisco
If I recall correctly , I believe * simply means that the status has recently been changed on this particular line. So it may not be relevant. Do you have the same problem on all 16 lines? A config could shed some more light.
~Zulfi
191
