Community Member
2621 Router Help
Can somebody please help. I have erased my flash image on my 2621 router. I have a copy saved to a tftp server, but i am having trouble reloading it. When i turn the router on it says that there is no flash image. How can i use the "tftpdnld" command to reload my IOS flash image. Please help.
1 ACCEPTED SOLUTION
Re: 2621 Router Help
You can follow this link
There are 5 parameters that needs to be set before using tftpdnld.
Those parameters should be entered exactly asis in the document.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_installation_guide_chapter09186a008007e02e.html
Community Member
171
