Community Member
2811 router boot problem
HI
I have 2811 router when i boot the under following error message comes. comes in roomon mode . I upgrade IOS but same problem arise.
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(3c), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Sat 07-Jan-06 04:34 by alnguyen
Image text-base: 0x400A1678, data-base: 0x42D00000
****** ERROR detected on PCI0 Bus
****** Try RESEATING all modules in the system
****** pci0_int_cause 0x00000040,
****** pci0_err_addr 0x30B08038, pci0_err_cmd 0x00000006
****** PCI Master Read Parity Error
%ERR-1-FATAL: Fatal error interrupt, reloading
err_stat=0x0
=== Flushing messages (09:11:27 UTC Wed Jul 19 2006) ===
Queued messages:
09:11:27 UTC Wed Jul 19 2006: Interrupt exception, CPU signal 22, PC = 0x0
-Traceback= 0x4025E7B8 0x4008B1C4 0x4025FAA4
$0 : 00000000, AT : BFA00000, v0 : 00000000, v1 : 45620000
a0 : 00000006, a1 : 00000000, a2 : 00000005, a3 : 000F4240
t0 : 000186A0, t1 : 00000000, t2 : 34008000, t3 : FFFF00FF
t4 : 4008E950, t5 : 00000000, t6 : 00008140, t7 : 45DAA238
s0 : 45618048, s1 : 45660000, s2 : 44F10000, s3 : 452E0000
s4 : 453D0000, s5 : 00000016, s6 : 00000000, s7 : 45DAA818
t8 : 00000000, t9 : 00000006, k0 : 00000018, k1 : 00000000
gp : 453E07EC, sp : 45DAA770, s8 : 45A8D120, ra : 4025E7A8
EPC : 4025E7B8, ErrorEPC : 400011AD, SREG : 34008003
MDLO : 000003E8, MDHI : 00000000, BadVaddr : 00000118
Cause 0000000C (Code 0x3): TLB (store) exception
No warm reboot Storage
*** System received a Bus Error exception ***
signal= 0xa, code= 0xc, context= 0x4561a104
PC = 0x4009483c, Cause = 0x20, Status Reg = 0x34008002
System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
Copyright (c) 2005 by cisco Systems, Inc.
thanks
biplob
it is hardware problem ????.
can any one help to solve this problem.
thanks
Biplob
Re: 2811 router boot problem
(1)What are the Interface cards inserterd?If there are,pls remove them and see.
JD
Silver
For the problem mentioned see the cause below,
ERROR: The system encounters a 'Bus Error' when the processor tries to access
a memory location that either does not exist (indicating a software issue) or does
not respond properly (indicating a hardware issue).
TRY THIS:
1. For 68000 Processor based platforms, carry out the following steps:
Consider the output:
"System restarted by bus error at PC 0x30EE546, address 0xBB4C4".
Here the system is trying to access the address "0xBB4C4"
a. Based on the address accessed by the router when the 'Bus Error' occurred,
use the "show region" command to determine the memory location to which
the address corresponds. If the address reported by the 'Bus Error' does
not fall within the ranges displayed in the show region output, it implies
that the router was trying to access an invalid address. This in turn indicates
a Cisco IOS Software problem. Use the Output Interpreter to decode the output
of the "show stacks" command to identify the software bug that is causing
the bus error.
b. If the address falls within one of the ranges in the "show region" output,
it implies that the router was accessing a valid memory location, but the
hardware corresponding to that address did not respond properly. This indicates
a hardware problem. Find the memory address that the system is trying to
access (for example in the above output, it is 0xBB4C4), and also the range
of memory addresses between which this address falls. The hardware issue
is most likely related to the corresponding component. If a new router has
been installed, or if the router has been moved from one location to another,
the memory chips may have become loose. It is recommended that you re-seat
or firmly push the memory chips into the slot.
For more information, see Troubleshooting Bus Error Crashes.
2. For the RISC Processor based platforms, use the Output Interpreter Tool to decode
the output of the "show stacks" command and identify the Cisco IOS Software
bug that is causing the bus error.
and even it is very much look like a bug in the software.
Rate if it does,
Rgs,
Community Member
Had this same issue.
Resolved by powering it off, opening it up, removing and re-seating all cards/RAM/etc. in the whole device, putting it back together, powering it back up.
1369
