2851 with Etherswitch vlans and dhcp -- oh my
I am missing something really simple, but for the life of me I cant figure it out. I have a 23 port etherswitch with 3 vlans 2 of which I will eventually connect back to a vpn and the 3rd (vlan 100) I want to throw out the local internet only.
My problem is that although I can get DHCP addresses on all vlans, I cant get to the internet. The router console can successfully ping things on the Internet but none of the vlans can.
I am attaching the router and switch module configs and help would be greatly appreciated.
1 ACCEPTED SOLUTION
Hall of Fame Super Bronze
Re: 2851 with Etherswitch vlans and dhcp -- oh my
Scott,
1) You need an ip nat statement describing the source list and destination interface.
2) You need to include the other networks in the trunk as part of the nat.
Here is your config with the changes
! Last configuration change at 12:08:35 EDT Mon Aug 28 2006
! NVRAM config last updated at 12:30:10 EDT Mon Aug 28 2006
version 12.4
service timestamps debug datetime msec show-timezone
service timestamps log datetime msec show-timezone
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
clock timezone EST -5
clock summer-time EDT recurring
ip cef
no ip dhcp use vrf connected
ip dhcp pool Beard_Voice
network 10.10.131.0 255.255.255.0
default-router 10.10.131.3
dns-server 137.123.221.69
ip dhcp pool Beard_Data
network 137.123.131.0 255.255.255.0
default-router 137.123.131.3
ip dhcp pool Beard_RR
network 172.30.100.0 255.255.255.0
default-router 172.30.100.1
dns-server 24.92.226.173
voice-card 0
no dspfarm
interface GigabitEthernet0/0
ip address dhcp
ip nat outside
ip nat enable
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet1/0
ip address 1.2.3.5 255.255.255.0
interface GigabitEthernet1/0.100
encapsulation dot1Q 100
ip address 172.30.100.1 255.255.255.0
ip nat inside
interface GigabitEthernet1/0.131
encapsulation dot1Q 131
ip nat inside
ip address 137.123.131.3 255.255.255.0
interface GigabitEthernet1/0.331
encapsulation dot1Q 331
ip nat inside
ip address 10.10.131.3 255.255.255.0
router eigrp 100
network 10.0.0.0
network 137.123.0.0
network 172.30.0.0
no auto-summary
no eigrp log-neighbor-changes
ip nat inside source list 1 interface GigabitEthernet0/0 overload
access-list 1 permit 172.30.100.0 0.0.0.255
access-list 1 permit 137.123.131.0 0.0.0.255
access-list 1 permit 10.10.131.0 0.0.0.255
ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 g0/0
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
line con 0
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
login
scheduler allocate 20000 1000
end
Hall of Fame Super Silver
Scott
Am I correct in assuming that your path to the Internet is through interface Gig0/0?
I see that you have NAT inside and NAT outside configured on interfaces. But I do not see any other NAT configuration. This will be a problem in getting to the Internet.
But the biggest problem that I am seeing so far is that your router does not seem to have a default route.
Rick
Yes gig0/0 is where we will be plugging in the ISP. Right now it is in a test isp connection we have in our office where we only get DHCP, but at the actual site we will have static addresses. So I guess I should create a loopback interface and assign an IP address to set that staic route to (or am I over thinking it)
Scott
I think that you are on the right track. I am not sure that I think that you need to create a loopback interface for this. There are many reasons to create and use loopback addresses and it may or may not be a good thing for you to have. But I do not see a loopback as part of the solution for this routing issue.
If you could tell us a bit more about your testing environment we might be able to give better answers. At this point my advice would be to set up a default route using one of the available options. You could just do ip route 0.0.0.0 0.0.0.0 gig0/0. This would work if a device that you connect to supports proxy ARP. I would not want to do this as a long term implementation because the default route pointed at a LAN interface requires proxy ARP, and can impact performance of the router. But in a testing environment it should work ok.
Another alternative is to configure a default route pointing to a next hop address through the Gig0/0. I see that you are learning an address through DHCP in your test environment, but if there is a router connected through that interface which has a fixed address then you could use that for the next hop in the default route.
Rick
Scott,
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
voice-card 0
no dspfarm
ip address dhcp
ip nat outside
ip nat enable
duplex auto
speed auto
no ip address
duplex auto
speed auto
ip nat inside
ip nat inside
ip nat inside
router eigrp 100
network 10.0.0.0
network 137.123.0.0
network 172.30.0.0
no auto-summary
ip http server
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
line con 0
line aux 0
line 66
no exec
transport input all
line vty 0 4
login
end
528
