04-05-2006 01:21 AM - edited 03-03-2019 02:39 AM
I have switch 2900 series XL losing the password and the Mode Button not work. What i can do for this problem? Please give a solution.
Wawan Kurniawan
04-05-2006 01:44 AM
If you have lost the password, you can recover it using the procedure in the following document:
http://www.cisco.com/warp/public/474/pswdrec_2900xl.html
Pls do remember to rate posts.
Paresh
04-05-2006 04:36 AM
Thank's Mr. Paresh for your reply.
But the problem is the Mode Button is not work or crash.
Pls another solution
Wawan Kurniawan
04-05-2006 04:42 AM
Another thing you can try it to break the booting sequence. Reboot your switch and press ctrl+break key and it should take you to the rommon. It may not work on your switch but you can give it a try.
You can then follow the recovery procedure if it gets you in.
Otherwise get switch replaced as the mode button is crashed.
HTH, Please rate if it does.
-amit singh
