Webcast-Catalyst9k
2900 series XL problem
I have switch 2900 series XL losing the password and the Mode Button not work. What i can do for this problem? Please give a solution.
Wawan Kurniawan
Purple
Re: 2900 series XL problem
If you have lost the password, you can recover it using the procedure in the following document:
http://www.cisco.com/warp/public/474/pswdrec_2900xl.html
Pls do remember to rate posts.
Paresh
Thank's Mr. Paresh for your reply.
But the problem is the Mode Button is not work or crash.
Pls another solution
Wawan Kurniawan
Another thing you can try it to break the booting sequence. Reboot your switch and press ctrl+break key and it should take you to the rommon. It may not work on your switch but you can give it a try.
You can then follow the recovery procedure if it gets you in.
Otherwise get switch replaced as the mode button is crashed.
HTH, Please rate if it does.
-amit singh
121
