2900 switch and VLAN problem (rant)
We are installing about 270 2900 series switches. We made a cookie-cutter configuration for all the switches. The first 20 or so worked fine. As more were installed, we noticed the switches worked, but were not pingable.
I went to one of the stores and noticed VLAN1 was administratively down. How?? I checked the IOS version.
12.0 (5.3) was the working IOS.
12.1(9) didn't work.
I changed the script so that the last thing we do in the config is no shut on the VLAN1 interface, but what a dumb move on Cisco's part!!!
Steve Olson
1 REPLY
Silver
Re: 2900 switch and VLAN problem (rant)
Sounds like you have some 2900XLs and some 2950s. The default must be different in the 12.1 code.
96
