09-08-2003 07:21 AM - edited 03-02-2019 10:11 AM
Hello all, I have had recent thunderstorms in the area and one building got a pretty bad power surge, bad enough to fry some hardware on a 2900M XL. I've reloaded a new image but now the switch is getting these error messages and keeps rebooting? I don't think this switch will ever be right again, maybe some critical circuity has been fried due to the the electrical jolt?
Here are my error messages on boot-up....
Initializing C2900XL flash...
flashfs[1]: 3 files, 1 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 3612672
flashfs[1]: Bytes used: 1495552
flashfs[1]: Bytes available: 2117120
flashfs[1]: flashfs fsck took 6 seconds.
flashfs[1]: Initialization complete.
...done Initializing C2900XL flash.
C2900XL POST: System Board Test: Passed
C2900XL POST: CPU Buffer Test: Passed
C2900XL POST: CPU Notify RAM Test: Passed
C2900XL POST: CPU Interface Test: Passed
C2900XL POST: Testing Switch Core: Passed
C2900XL POST: Testing Buffer Table: Passed
C2900XL POST: Data Buffer Test: Passed
C2900XL POST: Configuring Switch Parameters: Passed
C2900XL POST: Ethernet Controller Test: Passed
C2900XL POST FAILURE: front-end post: FastEthernet0/1:
C2900XL POST FAILURE: looped-back packet not received
C2900XL POST FAILURE: front-end post: FastEthernet0/2:
C2900XL POST FAILURE: front-end post: FastEthernet0/3:
C2900XL POST FAILURE: front-end post: FastEthernet0/4:
C2900XL POST: MII Test: Passed
cisco WS-C2924M-XL (PowerPC403GA) processor (revision 0x11) with 8192K/1024K byt
es of memory.
Processor board ID 0x10, with hardware revision 0x03
Last reset from power-on
09-10-2003 07:03 AM
...It would appear that your ports got fried. Try to reinstall the image; if the ports still fail POST, it's time to go shoppin.
09-15-2003 01:53 PM
I had this issue with a client after the Black Out here in New England. The only resolution was to get an under warrenty replacement for it.
