2900mXL switch won't boot HELP PLEASE!!!!!!! asap
Hello all, I've erase the NVRAM old IOS version of 12.0(5)WC3b and while I still had the console I copied the new IOS version that I wanted via tftp which was 12.0(5.1)XP Now, my switch won't boot up properly!!!! I need to get this switch into the production environment by the end of today, can anyone help? If not I guess I can open a TAC case. This is the error message I'm getting, look towards the bottom where it says "PERMISSION DENIED" I've tried to set the BOOT FS: to RW but it won't let me, please HELP!!!!
2900XL Boot Loader (C2900-HBOOT-M) Version 12.0(5.1)XP, MAINTENANCE INTERIM SOFTWARE
Compiled Fri 10-Dec-99 11:06 by cchang
starting...
Base ethernet MAC Address: 00:01:42:5e:b5:00
Xmodem file system is available.
Initializing Flash...
flashfs[0]: changing status of block 20 from "committed" to "in use".
flashfs[0]: Checking block 21...bad block number (-1)
flashfs[0]: erasing block 21...done.
flashfs[0]: 27 files, 4 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 3612672
flashfs[0]: Bytes used: 3020288
flashfs[0]: Bytes available: 592384
flashfs[0]: flashfs fsck took 8 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
Loading "c2900XL-h2s-mz-120.5.1-XP.bin"...c2900XL-h2s-mz-120.5.1-XP.bin: permission denied
Re: 2900mXL switch won't boot HELP PLEASE!!!!!!! asap
Does the switch go back to "switch:" prompt? Can you paste the output of "dir flash:"? if you have not tried a manual boot with command "boot flash:file_name", try it.
Yes, I believe I have tried the "boot flash:file_name" but if you look towards the bottom of this page you will see that there is no file in flash, I deleted the original and now I'm STUCK :-( It says I don't have proper permission.
switch: dir flash:
Directory of flash:/
3 -rwx 102893 c2900XL-diag-mz-120.5.1-XP
4 drwx 768 html
6 -rwx 1490614 c2900XL-h2s-mz-120.5.1-XP.bin
180 -rwx 109 info
181 -rwx 556 vlan.dat
19 -rwx 345 env_vars
17 -rwx 8192 e2rb.bin
18 -rwx 109 info.ver
20 -rwx 2673 config.text
592384 bytes available (3020288 bytes used)
switch: dir
List of filesystems currently registered:
flash[0]: (read-write)
xmodem[1]: (read-only)
null[2]: (read-write)
bs[3]: (read-only)
switch:
Yes, it does go back to switch prompt but with limited commands
switch: ?
? -- Present list of available commands
boot -- Load and boot an executable image
cat -- Concatenate (type) file(s)
copy -- Copy a file
delete -- Delete file(s)
dir -- List files in directories
flash_init -- Initialize flash filesystem(s)
format -- Format a filesystem
fsck -- Check filesystem consistency
help -- Present list of available commands
load_helper -- Load and initialize a helper image
memory -- Present memory heap utilization information
mkdir -- Create dir(s)
more -- Concatenate (display) file(s)
rename -- Rename a file
reset -- Reset the system
rmdir -- Delete empty dir(s)
set -- Set or display environment variables
set_bs -- Set attributes on a boot sector filesystem
set_param -- Set system parameters in flash
sleep -- Sleep a specified number of seconds
trap -- Cause a software breakpoint to occur
type -- Concatenate (type) file(s)
unset -- Unset one or more environment variables
version -- Display boot loader version
switch:
I am going to try using Xmodem to bring this puppy back to life.
Here is where I found it..
http://www.cisco.com/warp/public/473/36.shtml#xmodem
Thanks for your help all :-)
135
