2924 keeps rebooting after a few minutes
My 2924 keeps rebooting after a few minutes.
I loaded the latest ios and it failed loading.
after installing an older ios the switch has been functional and can be reached by ip and console.
but why is it keeping rebooting???
any advise will be welcome.
followed by switch output:
%Software-forced reload
Buffered messages:
%SYS-5-CONFIG_I: Configured from memory by console
%SYS-5-RESTART: System restarted --
IOS (tm) C2900XL Software (C2900XL-HS-M), Version 11.2(8.5)SA6, MAINTENANCE INTE
RIM SOFTWARE
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Fri 08-Oct-99 16:43 by cchang
Queued messages:
validblock_diagnose, code = 1
current memory block, bp = 0x700397C8,
memory pool type is I/O
data check, ptr = 0x700397EC
next memory block, bp = 0x700398CC,
data check, ptr = 0x700398F0
previous memory block, bp = 0x700396C4,
data check, ptr = 0x700396E8
%SYS-3-OVERRUN: Block overrun at 700397C8 (redzone 00000000)
-Traceback= D12AC 1225A0 124B54 125714 12589C
%SYS-6-MTRACE: malloc: addr,pc
3FD3A8,974C4 3FD3A8,122228 3DF58C,974C4 3FD3A8,122228
3DF58C,974C4 3FD3A8,122228 3DF58C,974C4 3FD3A8,122228
%SYS-6-MTRACE: free: addr,pc
3DF58C,96B6C 3FD3A8,12B6EC 3DF58C,96B6C 3FD3A
3DF58C,96B6C 3FD3A8,12B6EC 3DF58C,96B6C 3FD3A8,12B6EC
%SYS-6-BLKINFO: Corrupted redzone blk 700397C8, words 112, alloc 101D48, InUse,
dealloc 0, rfcnt 1
%SYS-6-MEMDUMP: 0x700397C8: 0xAB1234CD 0x16 0x360754 0x25CDCC
%SYS-6-MEMDUMP: 0x700397D8: 0x101D48 0x700398CC 0x700396D8 0x80000070
Exception (8192)! Debug Exception (Could be NULL pointer dereference)
CPU Register Context:
Vector = 0x00002000 PC = 0x0013B5B4 MSR = 0x00029200 CR = 0x22000042
LR = 0x0013B5B4 CTR = 0x00134B14 XER = 0x2000000
R0 = 0x0013B5B4 R1 = 0x00311CF0 R2 = 0x00000000 R3 = 0x00000000
R4 = 0x00000000 R5 = 0x00313314 R6 = 0x00000002 R7 = 0x00000000
R8 = 0x002E0000 R9 = 0x002E0000 R10 = 0x00000000 R11 = 0x00029200
R12 = 0x22000042 R13 = 0x00000000 R14 = 0x00000000 R15 = 0x00000000
R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000
R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x00000000
R24 = 0xAB1234CD R25 = 0xAB1234CD R26 = 0x00000001 R27 = 0x0025D190
R28 = 0x700397EC R29 = 0x002B7478 R30 = 0x002D5A84 R31 = 0x00000000
Stack trace:
PC = 0x0013B5B4, SP = 0x00311CF0
Frame 00: SP = 0x00311D00 PC = 0x0013B5B4
Frame 01: SP = 0x00311D20 PC = 0x001225D0
Frame 02: SP = 0x00311D50 PC = 0x00124B54
Frame 03: SP = 0x00311D68 PC = 0x00125714
Frame 04: SP = 0x00311D80 PC = 0x0012589C
Frame 05: SP = 0x00000000 PC = 0x0013FA50
C2900XL Boot Loader (C2900-HBOOT-M) Version 11.2(8)SA3, RELEASE SOFTWARE (fc1)
Compiled Fri 11-Sep-98 17:00 by rheaton
starting.
Base ethernet MAC Address: 00:50:e2:b2:ae:80
Xmodem file system is available.
Initializing Flash...
flashfs[0]: 173 files, 5 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 1728000
flashfs[0]: Bytes used: 1628160
flashfs[0]: Bytes available: 99840
flashfs[0]: flashfs fsck took 3 seconds.
...done Initializing Flash.
Loading "flash:c2900XL-hs-mz-112.8.5-SA6.bin"...################################
File "flash:c2900XL-hs-mz-112.8.5-SA6.bin" uncompressed and installed, entry poi
nt: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman
San Jose, California 95134-1706
%SYS-5-RESTA
IOS (tm) C2900XL Software (C2900XL-HS-M), Version 11.2(8.5)SA6, MAINTENANCE INTErating System Software
IOS (tm) C290
RIM SOFTWARE(C2900XL-HS-
Compiled Fri 08-Oct-99 16:43 by cchangARE
Image text-base: 0x00003000, data-base: 0x0020E5C0
Initializing C2900XL flash...
C2900XL INIT:
flashfs[5]: 173 files, 5 directoriesh>
switch>
%Software-
flashfs[5]: 0 orphaned files, 0 orphaned directorieses:
flashfs[5]: Total bytes: 1728000
flashfs[5]: Bytes used: 1628160started --
C2900XL POST: MII Test: Passed
cisco WS-C2924-XL (PowerPC403GA) processor (revision 0x11) with 4096K/640K bytes
3CB11C,122228
of memory. 3FAAC
Processor board ID 0x07, with hardware revision 0x00
%SYS-6-MTR
Processor is running Enterprise Edition Software
Cluster member switch capable
24 Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:50:E2:B2:AE:80
Motherboard assembly number: 73-2910-06
Motherboard serial number: FAA02519FJS
System serial number: FAA0251Z0FC
Press RETURN to get started!
RIM SOFTWARE
C2900XL INIT: Complete
switch>
1 REPLY
Re: 2924 keeps rebooting after a few minutes
Try erasing the flash and re-flashing it with the "known good" code.
200
