2924 xl en question about making it a hub
Hi there
I have a2924 xl en switch and i set all the ports to 100 and duplex full. here is my question how can i use it as a hub to hub link using a plain ethernet cable the blue ones and a normal hub with uplink. any help would be appreciated
1 REPLY
Re: 2924 xl en question about making it a hub
As a start, you don't want to have a hub link as full duplex unless you are ABSOLUTELY sure the hub supports it. Even if they say they do, hubs are notorious for barfing on full duplex. The rest of the question I don't quite understand. Are you trying to connect the switch to the hub, or are you trying to make the switch _act_ like a hub? It's a little unclear from your post title.
105
