Webcast-Catalyst9k
2924XL port LED Amber
I have a 2924XL problem, 5 of the port LED is AMBER (forever even if I remove the cable and the port is not working anymore) and the system LED is also AMBER. Is this a sign of hardware failure?
I did the following troubleshooting;
1. shut/unshut
2. duplex-full/speed-100
3. spanning-tree
4. upgrade the ios
5. hard reboot
all doesn't solve the problem. Any help?
Re: 2924XL port LED Amber
See how system is booting by connecting console cable.Check whether POST is successful.you can use show post command for this
I have a second switch (2924XL) in a remote site and one port is behaving the same. I reboot the switch and did "sh post" the result is "POST FAILED: FastEthernet0/19" I've check the cisco web site and found that this is hardware failure. I execute the same command in the original problem switch without rebooting it because its on production, and have the following results;
FastEthernet0/9 failed front-end loopback test
FastEthernet0/10 failed front-end loopback test
FastEthernet0/11 failed front-end loopback test
FastEthernet0/12 failed front-end loopback test
FastEthernet0/20 failed front-end loopback test
I guess I need to send it for RMA. Forgot to say that I did check the log and there is nothing there but "up/down interface".
Thanks a lot!
Purple
Log into the switch and check the logs usually it will give you some indication if something is wrong .
Please keep in mind when you restart the switch the logs are wiped.
264
