Webcast-Catalyst9k
2948G L3 configuration help
Im currently employing a 2948G L3 switch/router doing our core routing with some fastetherchannel and two BVI's. This configuration was done through reading and browsing the internet for notes. Im currently encountering a problem that totally shuts down my network. On the two BVI's, one is Ok while the other often drops. On my 2948G I have all the servers and routers connected to BVI 1 while another is using BVI2. The BVI1 often goes down often and the only solution we found is to reload it.
A couple of subnets is directed to BVI1 where only one subnet is on BVI2. We bought a 3660 recently and hope to move all the routes to that router and let the 2948G L3 do the switching and fastetherchannel. Below is my configuration and I hope someone can point out my problem
ITC2948Switch#sho conf
Using 11312 out of 124920 bytes
! Last configuration change at 12:51:11 UTC Fri Jul 12 2002
! NVRAM config last updated at 12:51:12 UTC Fri Jul 12 2002
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname ITC2948Switch
sdm size ipx-bvi-network 32
sdm size ip-adjacency 2048
sdm size ipx-node 2048
sdm size ip-prefix 8192
sdm size ipx-network 6144
sdm size ip-mcast 3072
sdm size udp-flooding 256
sdm size l2-switching 1024
sdm autolearn
ip subnet-zero
bridge irb
interface Port-channel1
no ip address
no ip directed-broadcast
shutdown
hold-queue 300 in
interface Port-channel2
description Unicenter01 port 33_34
no ip address
bridge-group 1
hold-queue 300 in
interface Port-channel3
description Finsuvantsrv01 port 31_32
no ip address
bridge-group 1
hold-queue 300 in
interface Port-channel4
description ntsrv005 port 29_30
no ip address
bridge-group 1
hold-queue 300 in
interface Port-channel5
description Cache port 27_28
no ip address
bridge-group 1
hold-queue 300 in
interface Port-channel6
description SQL Production port 25_26
no ip address
bridge-group 1
hold-queue 300 in
interface Port-channel7
description nexchange port43-46
no ip address
bridge-group 1
hold-queue 300 in
interface FastEthernet1
description Netman
no ip address
duplex full
bridge-group 2
interface FastEthernet2
no ip address
no keepalive
duplex full
interface FastEthernet2.2
encapsulation isl 2
no ip redirects
bridge-group 2
interface FastEthernet3
description link_to_ITCSwitch
no ip address
duplex full
bridge-group 1
interface FastEthernet4
no ip address
shutdown
interface FastEthernet5
description Subnet 10.1.87.1
no ip address
duplex full
interface FastEthernet5.1
encapsulation isl 2
no ip redirects
bridge-group 2
interface FastEthernet6
no ip address
bridge-group 1
interface FastEthernet7
description ITC Frame-Relay Gateway
no ip address
bridge-group 1
interface FastEthernet8
no ip address
shutdown
interface FastEthernet9
description dialup_router1
no ip address
duplex half
speed 10
bridge-group 1
interface FastEthernet10
description dialup_router2
no ip address
duplex half
speed 10
bridge-group 1
interface FastEthernet11
description gateway_router2
no ip address
speed 10
bridge-group 1
interface FastEthernet12
description gateway_router1
no ip address
duplex half
speed 10
bridge-group 1
interface FastEthernet13
description LNSRV010
no ip address
duplex full
bridge-group 1
interface FastEthernet14
description Ntsrv003
no ip address
bridge-group 1
interface FastEthernet15
description ntdc01
no ip address
bridge-group 1
interface FastEthernet16
description ntsrv001
no ip address
bridge-group 1
interface FastEthernet17
description ntsrv002
no ip address
bridge-group 1
interface FastEthernet18
description ntdc04
no ip address
bridge-group 1
interface FastEthernet19
description TNG02
no ip address
bridge-group 1
interface FastEthernet20
description Link to Qmail-temp exchange
no ip address
duplex full
bridge-group 1
interface FastEthernet21
description NTSRV008
no ip address
bridge-group 1
interface FastEthernet22
description Web Serv Test
no ip address
shutdown
bridge-group 1
interface FastEthernet23
description unicenter02
no ip address
bridge-group 1
interface FastEthernet24
description spare port for itcsuvantsrv02
no ip address
bridge-group 1
interface FastEthernet25
description Production_SQL
no ip address
duplex full
channel-group 6
interface FastEthernet26
no ip address
duplex full
channel-group 6
interface FastEthernet27
description cache
no ip address
duplex full
channel-group 5
interface FastEthernet28
description cache
no ip address
duplex full
channel-group 5
interface FastEthernet29
no ip address
duplex full
channel-group 4
interface FastEthernet30
no ip address
duplex full
channel-group 4
interface FastEthernet31
description finsuvantsrv01
no ip address
duplex full
channel-group 3
interface FastEthernet32
no ip address
duplex full
channel-group 3
interface FastEthernet33
description unicenter01
no ip address
duplex full
channel-group 2
interface FastEthernet34
no ip address
duplex full
channel-group 2
interface FastEthernet35
description TNG01
no ip address
duplex full
bridge-group 1
interface FastEthernet36
description TNG03
no ip address
duplex full
bridge-group 1
interface FastEthernet37
description itcsuvantsrv03
no ip address
bridge-group 1
interface FastEthernet38
description itcsuvantsrv01
no ip address
bridge-group 1
interface FastEthernet39
description itcsuvantsrv08
no ip address
bridge-group 1
interface FastEthernet40
description TNG04
no ip address
shutdown
bridge-group 1
interface FastEthernet41
description irdsuvantsrv01
no ip address
bridge-group 1
interface FastEthernet42
no ip address
shutdown
interface FastEthernet43
description nexchange01
no ip address
duplex full
channel-group 7
interface FastEthernet44
no ip address
duplex full
channel-group 7
interface FastEthernet45
no ip address
duplex full
channel-group 7
interface FastEthernet46
no ip address
duplex full
channel-group 7
interface FastEthernet47
no ip address
shutdown
interface FastEthernet48
description fibre link to IRD_Education
no ip address
duplex full
speed 100
bridge-group 1
interface GigabitEthernet49
no ip address
bridge-group 1
interface GigabitEthernet50
no ip address
bridge-group 1
interface BVI1
description Govnet_Bridgegroup
ip address 10.1.85.22 255.255.255.0
interface BVI2
description ITC_bridge-group
ip address 10.1.87.1 255.255.255.0
no ip route-cache cef
router eigrp 100
network 10.0.0.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.85.1 permanent
ip route 10.1.1.0 255.255.255.0 10.1.85.5
ip route 10.1.2.0 255.255.255.0 10.1.85.20
ip route 10.1.3.0 255.255.255.0 10.1.85.23
ip route 10.1.6.0 255.255.255.0 10.1.85.5
ip route 10.1.7.0 255.255.255.0 10.1.85.5
ip route 10.1.10.0 255.255.255.0 BVI1
ip route 10.1.11.0 255.255.255.0 10.1.85.20
ip route 10.1.12.0 255.255.255.0 BVI1
ip route 10.1.13.0 255.255.255.0 10.1.85.23
ip route 10.1.14.0 255.255.255.0 BVI1
ip route 10.1.19.0 255.255.255.0 BVI1
ip route 10.1.21.0 255.255.255.0 BVI1
ip route 10.1.25.0 255.255.255.0 10.1.85.20
ip route 10.1.26.0 255.255.255.0 10.1.85.23
ip route 10.1.30.0 255.255.255.0 BVI1
ip route 10.1.35.0 255.255.255.0 BVI1
ip route 10.1.40.0 255.255.255.0 BVI1
ip route 10.1.45.0 255.255.255.0 10.1.85.20
ip route 10.1.46.0 255.255.255.0 BVI1
ip route 10.1.48.0 255.255.255.0 10.1.85.20
ip route 10.1.51.0 255.255.255.0 10.1.85.5
ip route 10.1.55.0 255.255.255.0 BVI1
ip route 10.1.56.0 255.255.255.0 10.1.85.5
ip route 10.1.57.0 255.255.255.0 10.1.85.23
ip route 10.1.70.0 255.255.255.0 BVI1
ip route 10.1.71.0 255.255.255.0 BVI1
ip route 10.1.75.0 255.255.255.0 10.1.85.5
ip route 10.1.77.0 255.255.255.0 10.1.85.5
ip route 10.1.80.0 255.255.255.0 10.1.85.23
ip route 10.1.81.0 255.255.255.0 10.1.85.20
ip route 10.1.84.0 255.255.255.0 BVI1
ip route 10.1.85.0 255.255.255.0 BVI1
ip route 10.1.86.0 255.255.255.192 10.1.85.2
ip route 10.1.86.64 255.255.255.192 10.1.85.3
ip route 10.1.87.0 255.255.255.0 BVI2
ip route 10.1.91.0 255.255.255.0 10.1.85.23
ip route 10.1.92.0 255.255.255.0 10.1.85.23
ip route 10.1.93.0 255.255.255.0 10.1.85.23
ip route 10.1.96.0 255.255.255.0 BVI1
ip route 10.1.97.0 255.255.255.0 BVI1
ip route 10.1.103.0 255.255.255.0 10.1.85.20
ip route 10.1.105.0 255.255.255.0 BVI1
ip route 10.1.108.0 255.255.255.0 BVI1
ip route 10.1.109.0 255.255.255.0 10.1.85.23
ip route 10.1.111.0 255.255.255.0 10.1.85.5
ip route 10.1.113.0 255.255.255.0 BVI1
ip route 10.1.115.0 255.255.255.0 10.1.85.23
ip route 10.1.116.0 255.255.255.0 10.1.85.23
ip route 10.1.117.0 255.255.255.0 10.1.85.23
ip route 10.1.118.0 255.255.255.0 10.1.85.23
ip route 10.1.119.0 255.255.255.0 10.1.85.23
ip route 10.1.120.0 255.255.255.0 10.1.85.23
ip route 10.1.121.0 255.255.255.0 10.1.85.20
ip route 10.1.125.0 255.255.255.0 BVI1
ip route 10.1.130.0 255.255.255.0 BVI1
ip route 10.1.132.0 255.255.255.0 BVI1
ip route 10.1.134.0 255.255.255.0 BVI1
ip route 10.3.70.0 255.255.255.0 10.1.85.23
ip route 10.4.0.0 255.255.0.0 10.1.85.20
ip route 10.7.0.0 255.255.0.0 10.1.85.23
ip route 10.10.0.0 255.255.0.0 10.1.85.23
ip route 10.13.0.0 255.255.0.0 10.1.85.23
ip route 10.160.0.0 255.255.0.0 10.1.85.5
ip http server
bridge 1 protocol ieee
bridge 1 route ip
bridge 2 protocol ieee
bridge 2 route ip
line con 0
exec-timeout 5 30
password 7 020C11481F02002858
login
transport input none
line aux 0
line vty 0 4
password 7 032F4E012D0E2D1E1C
login
end
Re: 2948G L3 configuration help
please try the lastest software available and if that doesn't fix the issue. please open a TAC case for further investigation
Where can I get the latest IOS for this model ? Can I download it from the cisco site. I have been looking for it for a long time but to no avail. Please help
Here you go. You can download 12.0(18)W5(22b) from
http://www.cisco.com/cgi-bin/tablebuild.pl/cat2948g-l3
LAN Switching software section in CCO is at
http://www.cisco.com/kobayashi/sw-center/sw-lan.shtml
105
