2948G-L3 switches-How to get IP addresses of the PCs connected ?
Hi !
I have around 30 PCs connected to different Fast Ethernet ports of the Catalyst switch router. I was just wondering if there is any way (using CiscoWorks 2000 or CLI commands) I can get a list of the IP addresses (or computer names) of all the PCs connected to each of the ports. Once I get that, I'll add a proper description to each port which will help me troubleshoot any connectivity problems in the future.
Kindly let me know if you have any idea about this or if you know of any other option I can use for this purpose.
Thanks.
Fareed,
Network Engineer, ATS
Re: 2948G-L3 switches-How to get IP addresses of the PCs connect
Show ip arp should give you that info.
show bridge verbose may give some more informaton.
I use Solar Winds Engineers edition.
http://www.solarwinds.net
Thanks for your respones. I'll try them at work tomorrow morning !
Thanks again.
Fareed
253
