01-17-2003 06:18 PM - edited 03-02-2019 04:18 AM
I guess I should have asked this the first time, I forgot to add it to the big picture.
Firewall Firewall
2948G-L3 2948G-L3 ------------ Layer 2 devices
Firewall Firewall
Basically the 2948G-L3 are running HSRP and have some VLANS. Port 49 of both 2948G-L3 goes to a Layer 2 device that they are providing HSRP for. Right now there is no link between the 2948G-L3's. I need to add a link connecting the 2948G-L3's to each other so if a single firewall fails on either side, hosts can still reach everything through the existing firewall.
Just not sure how to configure the link from 2948G-L3 to 2948G-L3.
One of the 2948G-L3 configs:
bridge irb
interface FastEthernet1
bridge-group 2
bridge-group 2 spanning-disabled
interface FastEthernet2
bridge-group 2
interface FastEthernet3
bridge-group 2
interface FastEthernet4
bridge-group 2
.........<omitted>
interface FastEthernet8
bridge-group 3
bridge-group 3 spanning-disabled
interface FastEthernet9
bridge-group 3
interface FastEthernet10
bridge-group 3
.........<omitted>
interface FastEthernet47
bridge-group 7
bridge-group 7 spanning-disabled
interface FastEthernet48
bridge-group 7
interface GigabitEthernet49 -----------> Physical connection to layer 2 User network
interface GigabitEthernet49.2 -----------> VLAN needed on here and layer 2 user network
encapsulation dot1Q 2
bridge-group 2
interface GigabitEthernet49.3 -----------> VLAN needed on here and layer 2 user network
encapsulation dot1Q 3
bridge-group 3
interface GigabitEthernet49.4 -----------> VLAN needed on here and layer 2 user network
encapsulation dot1Q 4
bridge-group 4
interface BVI 2
ip address 192.168.1.2 255.255.255.0
standby 2 ip address 192.168.1.1
standby 2 priority 110
bridge-group 2
interface BVI 3
ip address 192.168.2.2 255.255.255.0
standby 3 ip address 192.168.2.1
standby 3 priority 110
bridge-group 3
interface BVI 4
ip address 192.168.3.2 255.255.255.0
standby 4 ip address 192.168.3.1
standby 4 priority 110
bridge-group 4
interface BVI 5
ip address 10.0.1.2 255.255.255.0 --> VLAN needed only here
standby 5 ip address 10.0.1.1
standby 5 priority 110
bridge-group 5
interface BVI 6
ip address 10.0.2.2 255.255.255.0 --> VLAN needed only here
standby 6 ip address 10.0.2.1
standby 6 priority 110
bridge-group 6
interface BVI 7
ip address 10.0.3.2 255.255.255.0 --> VLAN needed only here
standby 7 ip address 10.0.3.1
standby 7 priority 110
bridge-group 7
bridge 1 protocol ieee
bridge 2 protocol ieee
bridge 3 protocol ieee
bridge 4 protocol ieee
bridge 5 protocol ieee
bridge 6 protocol ieee
bridge 7 protocol ieee
bridge 1 route ip
bridge 2 route ip
bridge 3 route ip
bridge 4 route ip
bridge 5 route ip
bridge 6 route ip
bridge 7 route ip
01-23-2003 08:33 AM
If you are looking to build plain and simple firewall redundancy and assuming that you are using PIX firewalls, the following docs will help you immensely. How Failover Works on the Cisco Secure PIX Firewall (http://www.cisco.com/warp/public/110/failover.html#lanbasedfailover) and Installing Failover (http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_60/install/failover.htm).
01-23-2003 03:47 PM
No i am not looking for firewall redundancy, I already have that. The top firewalls are Active-Active and the bottum firewalls are Active-Active. What I need is to add a link between the (2) 2948G so if either one of the top firewalls or either one of the bottum firewalls fail then traffic will continue to flow and not stop because it cant traverse from one 2948G to the other. But im not sure how this link should be configured between the (2) 2948G's.
01-24-2003 05:09 AM
Do you want to transport all VLANs over this link?
Then you need a trunk port. You can configure port to carry multiple VLANs.
Or do you want to create a fail-over link, then you need spanning tree.
Hope this helps.
Pim Sijnja
