Webcast-Catalyst9k
2948L3 switch with amber PS1 LED
I power cycled this switch and ever since then the unit comes up with an amber PS1 led indicator. All the documentation only mentions red for failed and green for ok. Nothing mentions amber.
I can not ping the switch nor does it pass traffic. When I connect a workstation to one of the ports, the workstation's NIC indicates a link. The switch, however, doesn't
Is this thing dead?
1 REPLY
Silver
Re: 2948L3 switch with amber PS1 LED
Check below :
http://www.cisco.com/univercd/cc/td/doc/product/l3sw/2948g-l3/rel_12_0/7wx515a/hardware/overview.htm
Any log message from the switch ? Are you confirm the amebr color is PS1 LED or other LED ?
106
