2950 AND IP PHONES-PC'S DO NOT HAVE CONNECTIVITY
Phones work...PC's don't....Any ideas? I add the PC to a static access port and I can ping everything. Same config on a 3550-24 works fine...weird....Oh, and the "switchport trunk encap dot1q" command is NOT available on this platform...even more weird....
Switch To Phone:
interface FastEthernet0/1
description IP phone and PC
switchport trunk native vlan 7
switchport mode trunk
switchport voice vlan 17
switchport priority extend cos 5
no ip address
Switch trunk to router:
interface FastEthernet0/12
description Trunk to 1760 router
no ip address
Router interface:
interface FastEthernet0/0
no ip address
speed auto
interface FastEthernet0/0.7
encapsulation dot1Q 7 native
ip address 192.168.7.254 255.255.255.0
interface FastEthernet0/0.17
encapsulation dot1Q 17
ip address 192.168.17.254 255.255.255.0
1 REPLY
Gold
Re: 2950 AND IP PHONES-PC'S DO NOT HAVE CONNECTIVITY
I have a 2950G-12 which works with IP Phones and PCs. All 10/100 ports are configured as VLAN trunk ports. IP Phones work on the voice VLAN, direct-connected PCs work on the native VLAN, and ports with IP Phones with PCs attached use both. Switch configuration was copied over from the 3524-PWR switches I have in every wiring closet. (This 2950 is the only non-powered one with IP Phones on it.)
I use the same commands as your "Switch to Phone" config on my 10/100 VLAN trunks, except I use "switchport priority extend cos 0" to make sure the inbound voice traffic on a port always gets priority over the PC's data traffic, whenever both an IP Phone and a PC are plugged into it. And I use "spanning-tree portfast" on the 10/100 trunk ports, to go straight from "no link" to forwarding.
I also have 2620 routers set up to do interVLAN routing using subinterfaces. The commands I'm using don't look any different than the ones you're using.
I don't see anything in your configs that sticks out like a sore thumb. What versions of IOS are you using on the router and switch?
As for the switchport encapsulation, if you create a VLAN trunk on a 2950 it's always going to use 802.1Q encapsulation. Cisco Catalyst 2950 Series does not support ISL trunking; and there are no plans to support it on that platform. Since encapsulation choice is not an option, there is no need for a command to specify one.
The Catalyst 3550 switches support both ISL and 802.1Q trunks, for those with a requirement to deploy ISL trunking.
Hope this helps.
93
