Webcast-Catalyst9k
2950 flash question
I managed to erase the flash. I have copied the new bin file back. I followed the instruction on the web on how to recover the IOS. When i reboot the switch it cant find the file flash and says the boot sequence vairable is not set!
Can someone tell me how to tell how to fix this?
1 REPLY
Re: 2950 flash question
Sounds like the boot variable is not set. From ROMMON to get the system in boot you need to initialize the flash and boot the image. This can be done by doing the following:
flash_init
load_helper
boot flash:whateveryourfilename.bin
This should boot the switch.
Once the switch is booted go into config mode and set the boot variable by entering:
boot system flash:whateveryourfilename.bin
The article in the following link explains this:
http://www.cisco.com/en/US/products/hw/switches/ps628/products_tech_note09186a0080169696.shtml
Hope this helps.
82
