2950 - input errors
I have 4 2950 in a cluster and I'm currently checking out a web server. I configured fast etherchannel with port group command, did the same on the server. Well, I'm getting errors and I was wondering, is ther anything I can do about these errors? The switches are running at 23% CPU, is that average?
dbcat04#sh int f 0/12
FastEthernet0/12 is up, line protocol is up
Hardware is Fast Ethernet, address is 0007.ecae.424c (bia 0007.ecae.424c)
Description: WEBCSS1
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 2/255, rxload 1/255
Keepalive not set
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input never, output 00:00:01, output hang never
Last clearing of "show interface" counters 4d22h
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 495000 bits/sec, 89 packets/sec
5 minute output rate 1065000 bits/sec, 188 packets/sec
47872986 packets input, 1754450121 bytes
Received 2873 broadcasts, 0 runts, 0 giants, 0 throttles
478 input errors, 0 CRC, 478 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast
118910801 packets output, 1052941249 bytes, 0 underruns
0 lost carrier, 0 no carrier
dbcat04#sh int f 0/13
FastEthernet0/13 is up, line protocol is up
Hardware is Fast Ethernet, address is 0007.ecae.424d (bia 0007.ecae.424d)
Keepalive not set
Last input never, output 00:00:48, output hang never
5 minute input rate 723000 bits/sec, 110 packets/sec
73776480 packets input, 1383782804 bytes
Received 4292 broadcasts, 0 runts, 0 giants, 0 throttles
30 input errors, 0 CRC, 30 frame, 0 overrun, 0 ignored
2230264 packets output, 700795236 bytes, 0 underruns
Re: 2950 - input errors
Looks like this is a software error. Try checking the Network Card Driver for a newer version. Another thing make sure that the Duplex/Speed is set hard coded on boths sides. If Problems occur still, even after software update of NIC, take it down half a notch to half duplex and see if the rate lowers or stops. 23% is ok for the utilization.
Corey
Yap, that web server had old crapy windows drivers. So, input errors means OS problems = drivers?
try connecting some other PC's to the same port.
Whether the errors are seen in all the ports?
Also try changing the cable.
108
