2950 not passing traffic except ICMP???
I had a 2950 that had a fan failure this weekend. It appears that the switch stopped passing traffic but it would pass ICMP and SNMP polls. It would also respond to polls so it appeared that all was well. Anyone ever heard of this before?
Silver
Re: 2950 not passing traffic except ICMP???
The problem may be due to GBIC hardware.
Check the hardware, if the issue is due to hardware failure then replace GBIC card.
Bronze
If you had a fan failure, then it sounds like some of your port banks my have failed on you as the system may have gotten too hot. Have you reloaded this switch? If so, and you are still having the problem, I would replace the unit. To test a couple of things, change your uplink port to a different port to see if you can still get ICMP and SNMP polls to the device. Hope this helps.
135
