Webcast-Catalyst9k
2950 problems
i have 2950 switch and the console port stop work
i can access it by Vty
but one of students change the enable password what i do to recover password and access it
Purple
Re: 2950 problems
The following document outlines the procedure you can use to recover the password on this switch:
http://www-tss.cisco.com/eservice/compass/common/activities/password_cat_2950.htm
Paresh
Re: 2950 problems
hi , thanks for fast response
but as i say the console port have a problem ,
how i recover password ,while the console port out of work {i can access it by VTY }
Re: 2950 problems
Did you try changing the different baud-rate or terminal emulation program.
If yes then,Sorry to say but if console port is dead you cannot recover it.
Go ahead and get the replacement for it. Open a TAC case and get a replacement 2950.
HTH, Please rate if it does.
-amit singh
155
